RTT - only allows to edit HO table, if I turn knock learn off will it run off HO only
Hey guys,
About to have my first try at RTT on the dyno,
in the past i have not used the enhanced OS and used the LO table only
after upgrading to enhanced OS i have copied my LO table to the HO and taken 5 degrees of timing out of the LO to make the knock learn work
i have noticed now that i have the knock learn kicking in and since you can only change the HO table in real time i find this annoying having to check in every cell im changing if knock learn has started kicking in.
if i set the knock learn enable multiplier table all to zero would it effectively make the car run off the HO table only?
thus being able to tune in real time without worrying if the knock learn is pulling my timing?
