Inaccurate wideband readings
I recently set my std. hptuners scanner to work with my wideband using my ac pressure sensor input to the pcm. However there is a slight issue...
I just realized something very important AFTER tuning my ve and maf tables. My scanner and lc-1 dynotune wideband display do not always match each other!! For instance, at 14.7:1 my display and scanner match. However the richer my wideband display reads the further away the scanner gets. At 12.0:1 on my display, the scanner is reading 12.8:1. At 12.5:1 on my display the scanner reads about 13.2:1. I found this out when making some wot pulls after tuning my ve/maf tables according to my scanner afr%error. What I noticed is that the scanner was saying is that my afr error is pretty close when in actuality it is a bit rich on my display but not the scanner. So what I did to confirm this was I happened to shut the car down when the wideband display was showing 12:1. So I turned the key on but did not crank it up so I know the afr would not be moving. I compared the scanner and display like this several times.
How do I fix this problem? Is it something in the scanner or something my analog out2 on the lc1 config??
