Does anyone have the specs for the 41lb injectors used in the Ford E-Force supercharger kits or can post a file that has them in it?
Thanks.
Thanks.
what year? the newer 5.0 have much larger injectors and you can run the stock no problem.
It's for the 2008 F150. The injectors are installed, I'm just looking for the correct values for them or at least what Edelbrock uses.
^most likely edlebrock scales the tunes. have you tried doing that?
I hope Eric can help you out.
That sounds awesome.
Would that injector data apply to a 2009 F150 5.4 with the Eforce as well?
Anybody have the eforce tune for a 2009 they can post up?
Well this truck just came in with the eforce on it to a local used car lot. Somebody must have put the PCM back to stock, so I am needing at least something to start with on this.
The 08 F150 I just finished, still used the 39.5psi fuel pressure. Guessing the 09 is different.
I have an E Force file for an 06 Mustang, but it would still be the 39.5 fp. If the 09 F150 is higher, just scale the values Eric posted for the higher fuel pressure and start there. Or call Edelbrock and see if they will give it up.
Here is a stock 2009 f150 file. Virtually identical to the truck I have here with the blower on it.
Attachment 46562
Just did an Eforce kit last week on an 08. The file that came with it wouldn't hardly drive at all...lol
