1 Attachment(s)
is there anywhere to adjust the acel enrichment?
having a lean tip in esp when leaving normal from a stop.. goes real lean just a sec then correct afr.. tune otherwise looks great.. doesn't show lean on ltft in the area.
I know on megasquirt and most others have a ae section to adjust I cant find anything that help this issue
accidentally erased my log just now... they really shouldn't have play button beside the start log button.. or not have it enabled when not connected to the tuner. you would think i would have learned by now but nope.... so ill try to get and post log after work
also is there anywhere to adjust the intake air temp vs fueling? tune looks great till after 91deg IAT then starts going lean goes from 0-1 ltft to 7-8 sometimes highter when it gets above that which is common here esp when you cut off car a few min
