0411 PCM power wires grounded
Hello everyone,
I don't post much on here, must just search around for information but at this point I'm completely lost and just need a little guidance.
I've been finishing up a motor swap with an 0411 pcm and can get it to crank but have no fuel or spark. I started to check all of my wiring and when I test continuity on my pcm power wires (pin blue 19.20.57) they are all grounded. They do not have continuity to the battery positive but if I touch them anywhere to the motor they have continuity. I did this with the pcm unplugged and the fuses are all good as well.
This isn't normal when the pcm is unhooked is it? With the pcm hooked up my scanner will still log but only shows the o2 sensor readings and the temp sensors, I can change the tune without any errors, and the fuel pump will prime but it won't start, just curious if the power wires to the pcm are my issue or if it is something else. The grounds on the motor and pcm are all good as well but I can't figure out this power wire issue.
Any help would be appreciated!
