EIO inputs, raw voltage reads 1.3 volts?
Trying to get my wideband working and I noticed with nothing conected to the aux. inputs they display voltage? I thought they should be 0 with nothing hooked up. I just added a raw voltage pid in the scanner to eio inputs 1-4, two of them were displaying about 1.295 volts and the other two were about 1.328 volts. When I had the lc-1 output 2.95 volts so I could check the offset in the scaner, I had to subtract 1.77volts to make it read 2.95. and then in the wideband pid it was volts/.625 + 7.168 to display 14.7 afr.? I had the range at 10-18 afr. Can anyone help explain this?
