engine TR Deleivered
engine deleivered trq in the pic is 640
from 3800 rpm when i hitted the throttle ( full )
and its start dropping on 6000 RPM
the car is boosted 12 PSI and it have slip in the belt
the question is ,,
is it my scanner ,, reading MAX number 640 ?
if yes ,,, is there is a way to look at greater then this number ??
i hope i can get some info about this information
cheers
If you right-click your chart and edit it, you can change the min/max values of the data you are logging. However, I think 640 is the upper limit for that specific data based on your tune. I may be incorrect.
i guess u are correct
its a shame that i didnt see the number ,, because its a camaro with 416
TVS2300
and i was hopping to look at a higher number ,,,
anyway ,, there was a Slip ,, and lets see what will i do for it :D
thanks ,, and i hope one of the support guys answer and feed us back with the engine Deleivered Trq
I have something better for you to use from a very smart man named Marcin:
http://redhardsupra.blogspot.com/201...1_archive.html
Marcin gives tips how to setup your charts to simulate HP/TQ if that is what you are trying to do, specifically the DynAir(G/sec) and DynCylAir(g/cyl). Set the upper limits when logging both so that you get a "Dyno chart" type effect.
His blog has a lot of good information that I recommend as reading to anyone that tunes be it the seasoned tuner or the noobie.
thanks for the link ,, its great
