Knock Learn Factor on E39
I'm trying to get a better understanding of how Knock Learn factor works on the E39. I understand that it starts at "0" (100% High Octane Table) and moves towards "1" (Low Octane Table) as it experiences knock - based on your knock learn settings.
However, what I don't understand is if it's a "global" thing or if it's a "per combination" type thing. For example, if I get knock at 2000 RPMs/0.44g/cyl and the Knock Learn value increases, does that knock learn value affect ALL RPM/Airmass combinations or just the 2000/0.44 combination?
From what I've seen in my scan logs, it almost looks like it's "per combination" becuase I will be reviwing my log and the Knock Learn value will go from 0.0 to 0.3 even though no knock has occured, so it seems to remember the RPM/airmass combination and keeps differernt values per combination... Is that correct?
Thank you!
