JTEC 5.2 Turbo 2 bar MAP questions
Good evening, new to HP tuners, but the jtec support inspired my latest project, an ?84 Dodge Diplomat with a 5.2 magnum and a gt45 turbo. Starting the tune and it seems like there isn?t a way to get rid of the map sensor reading baro on startup. Also I?m not sure what units the scaling on the map sensor data is in, so I?m not sure what (if anything) to change when using a gm 2 bar. It seems that there is no way to change the map reading scale in the tables, so I was thinking that 105kpa = 200kpa(actual) in the tune and ?trick? the pcm that way? If there is an easier way or a way to add cells for boost I haven?t found it yet. Any help would be awesome, I want to hear this thing rip! 🤘🤘🤘
