Detonation when getting into boost but no KR?
Hello,
I have been trying to figure out why my knock sensors will not read in hp tuners. I have been lowering my timming from a start up tune and increasing my boost safely as i can. I'm only up to 7lbs before I get into detonation that I can hear and feel and I'm worried that I might do some damage before I get it figured out. I have new sensors and harness, check the haress to the pcm and everything checks out.
Please give me some ideas, If i turned some thing off in the scan tool or some other problem.
The setup is a 5.3, ls6 cam,ls9 head gaskets,head studs,80lb seimen,pt76gts,truck manifolds
Also on a off note with a 2bar tune to lower the timming you have to do both HO/LO tables right.
Thanks for the info (still learning)
