so what is the word on this can we at least see what dtc our abs sets when the light comes on with out going to the dealer?
You dont need a scan tool to bleed the ABS system. I learned a little trick a few years ago when I replaced a module and my scan tool took a crap. Bleed as you normaly would but instead of pushing the brake pedal you cycle the key to the on position and bleed that way untill you get fluid from all 4 wheels. Then bleed as you normaly would.:cheers:Quote:
Originally Posted by MeentSS02
Could you explain this a little more clearly? I'm not quite tracking with you...do you mean open the bleeder valve, then turn the key to the on position, then close the valve before turning the key back off?Quote:
Originally Posted by 1slowsilverado
Ok i'll try to explain it alittle better. There is only 2 times you should have to bleed the ABS. If you have replaced EBCM/Manifold assy. But also applies to flushing the system as general maint.
If you replace the ebcm assy you will need to purge the air out with a scan tool or by tricking the system as you would have no brakes. You would do this by turning the key on untill the ABS light goes out do this 5 times. You would then open the RR bleeder then close it. Repeat this with the LR, RF and LF. You will need to do this unitll you get fluid from each wheel. (might take a while)Then bleed as you normaly would.
To flush the system, Bleed the system until you have clean fluid at each wheel. Then cycle the abs system in the same manner above. Untill you get clean fluid again.
Thanks for the info.
Ken, I can appreciate your position on the BCM. Undoubtedly, it's not a necessary function for some vehicles. But on others the BCM controls many things. So, may I suggest that you offer BCM write capabilities to a select few vehicles at first. As a C5 owner I would relish the ability to modify the BCM.Quote:
Originally Posted by Ken@HPTuners
I'd be happy if I could disable dash lights without removing it :(
Brake bais control would be great! I can't imagine there being more then 1 or 2 different ABS calibrations per vehicle.
i did an engine swap, ill bet i could use some features for that bcm
My Escalade has a ton of bcm fuctions that I would like to modify.
Here is an example...looking to drop 6.2L/6speed auto into my truck. Wiring looks pretty much plug and play, biggest issue will be the tranny gear display on the dash which comes from BCM. Will it display correctly?
BCM are same part number between all the trucks so no issue there, but if you want to flash it though tech II you need the VIN and then it won't recognize the 6 speed as my vin is 5.3L/4speed...be nice if a guy could sort all this out on his own.
Oh yeah, could add power folding mirrors too :)
Another nice thing that I've seen done is removing Autoride from vehicles....
+1 to ABS Purge ability. Giant PITA hack job (or a trip to find someone with a Tech 2 tool with iffy brakes) on 4th gen F-Body's otherwise.
The MPVI doesn't communicate on the ABS line. Not possible on those older vehicles.
