Does anyone have stock VE% vs. RPM vs. MAP tables they can post. Generally any vehicle will do.
Thanks,
:usa:
Thanks,
:usa:
There is a tune repository through the hp tuners site. Just log in with your account and there should be a link from that page.
Well, I have a customer account and can't seem to download anything. When I click on it, nothing happens.
Here you go...
THanks for the post, however, I can interpret the format :shrug:
Can you export it to excel?
If you don't have HPTuners, how do you expect to view a map/table?
If you have an LS motor why do you want info for a V6?
here is one from a 02 TA
http://i143.photobucket.com/albums/r...screenshot.jpg
Wanted the VE table to play around with it to see if I can create an equation that would produce VE values that match those in existing tables. So I needed a few tables to act as known working results. So if the data can be exported to excel, that would be ideal.
transamdroptp08, Thanks, but the resolution is too low to extract anything from the table posted.
Are these tables populated by values set by the manufacturer, or are they populated empirically while driving?
