Problem is not with your tune, you have a bad scanner vehicle data file. This is usually the correct path, if you installed differently you will have to find the path.
My Documents-Hptuners-VCM Scanner-Vehicles, should have files ending in .os. Delete all the files in the folder, then reconnect to the truck and 02 sensor should be there.
