What do "No Throttle" and "Throttle Only" mean for transmission torque management?
I've been trying to understand what each of these values really mean for the transmission torque management settings. I've found two completely different definitions so far:
First one:
- "No Throttle" means that torque control will be managed by spark adjustments.
- "Throttle Only" means that only the throttle but no spark adjustments will be used for torque management.
Second one:
- "No Throttle" is TM only on coast down or situations where the trans shifts under "no throttle" situations.
- "Throttle Only" is TM only while the throttle is applied.
Can anyone confirm which definitions are correct?
Thank you!
