3 Attachment(s)
Couple WOT runs Logs attchd
I made a couple WOT runs a few minutes ago. I have uploaded the logs. I am just hoping someone can look at the log and see if there is anything out of whack. I am mainly concerned with a little knock that is there on one pull and not the other and also the CylAir (g/cyl), it goes over 1.0 and my spark table only goes to 1.0, is this normal on a N/A setup. Also, can you please take a look at the commanded AFR vs Actual? Mods to the car are LS2 with LS3 top end, milled heads, long tubes, true dual X pipe and EPS cam 226/230 on a 110 +4. Also does the MAF (lb/min) look normal for a setup similar to this? I have a few custom histograms, one is Lambda MAF error% and Lambda AFR error%.
Thank you in advance for any pointers!
