2 Attachment(s)
Having a bad time getting cold start and return to idle 5.3l custom cam
Hi
I have been reading and tuning on and off when i can and trying to nut out this idle,anyway i would like some guidance on this idle problem iam having.
i have a cold start log and config file most recent i have,but still need to get my tune out of my other lap top so bare with me
till tommorow.
I had the iac counts down in the 40-60 range at idle but the engine would only achieve this after getting to running temp,
then it would come down from 280 to 230 iac to the 40-60 range,but only if i held the tps at 5% and slowly let my foot of to 0%.
Well after some more tuning and adjustments i can not seem to get my iac counts down at all now and return to idle when cold is not right again.
I have adjusted raf and spark,throttle blade tps volts and reset all the usual stuff to get idle better but its not working
consistently with what i see in my logs.
Should i just start over again and redo my tune?
its like iam trying to hit a moving target sometimes with this idle,any way ill load my tune here tommorow and maybe
someone can shed some light on what is happening.
The car is a drag car/street car with no narrow bands just a afr meter (not logged),engine is a lm7 5.3L with ls1 intake,custom turbo cam 232 238,just running na at the moment to get everthing
dialed in .iam running shorty headers and a 2x 2.5" to 3" single exhaust.
no VSS,power glide trans 3000 rpm 10" convertor,9" 4.11s 26" m/t drag radial
car is about 2800 lbs
