Cruze Sonic 1.4T spark table histogram cylinder airmass issues
Screen shots here stock tune Log (2013 Cruze LT 1.4T M32)
I am using the same PID for monitor Cylinder Airmass. However, I am not getting the same results in the histogram vs. chart. I took this config from my other vehicle, I did customize the scales in the histogram setup to match the RPM increments and g/cyl increments to match the Editor and reselected Cylinder Airmass for the row axis.
Referring to the screen shots, you can see the histogram never exceeds 0.30 g/cyl; however, the chart shows g/cyl getting to 0.60 g/cyl under WOT.
Which one is right? What did I goof up here?
