Trying to tune a 07 GT500, went to add fuel in the MAF transfer and after loading the tune the idle goes up and codes P061B and code P1227. Confused-put those 2 codes to no error reported and the same thing happens.
P061B is caused by having more than the allowed wheel torque error. This is what is causing the P1227 code. Disabling the codes does not keep the car from entering failsafe. The correct way to fix this is to dial in the drive by wire related tables, the easy fix is to raise the wheel torque error.
you are right but you should try to do it the correct way and dont want to have a run away issue, i have faith that having erics help know he would work on the data log pids needed to tune etc
