Files attached for different versions
Bringing this back from the dead. I made calibrations for the 4 basic versions of a 98 Camaro/Firebird.
The fuel system segment from a 2002 Express van is installed in each and the fuel level calibration was copied in from a 98 calibration. I don't have a vehicle to test these on so I need feedback or re-posts from anyone who tries these files out in their own car.
Note: You will have to license the file to install it in your particular car. You will need the Beta version (or 2.24 when available) to read them.
VATS is NOT disabled!
The only changes to these files from stock calibrations are the Fuel System segment swap and the fuel system values copied from the 98 base file.
Here are the files for standard PCM swap applications:
98 Manual transmission Attachment 24059
98 4L60E 2.73 gear ratio Attachment 24060
98 4L60E 3.23 gear ratio Attachment 24061
For those doing a 4L80E swap as well I also did this one:
98 4L80E 3.73 gear ratio Attachment 24062
