Can't Log Commanded AFR or AFR Error
After finally getting the set up completed mechanically, followed by a trip to the Paint/body shop (had accumulated a few scratches over the years)
I decided to take some time this Memorial weekend to delve into actually tuning my car.
06 GTO with a custom mid-mount twin turbo, TSP CNC'd LS3 heads/intake, TSP Cam 584/588 on a 114 LSA, 255lph in tank with Ls3 Injectors (I have my original LS2 injectors that I had re-done to 60# by FIC set-to go on)
The major issue I'm having is getting the scanner/histogram to work correctly with the config file (I've attached the config and the log).
As it stands, I can log my AEM wideband (I have it coming in through the Fuel Tank Pressure input). Default items such as AFR commanded and Error Percent won't log. Items I have in the Histogram (that show to be working before I connect to scanner) won't work either.
I've double checked (hell triplicated) all the calculations, searched/studied/ replicated histograms/configs I've found here and all to no avail.
So, before I threw in the towel I thought it prudent to ask for some help from those of you far more experienced than myself.
Any and all help is appreciated.
