2 Attachment(s)
Do I need a segment swap for a DBC setup on a DBW PCM?
Specs:
97 F-Body
LQ4 block
LS3 heads and intake
DBC throttle body
2004 Express Van 3500 PCM (Svc#:12586243 Hwd#: 12583659)
So I have a LQ4 with a 4L80e. I paired it with a Chevy Express Van 3500 PCM Attachment 46386 because I read around that it was really the last PCM that controlled a Gen 3 motor with a 4L80e and had the IAC driver chip. I got it all hooked up and cranked the motor and get a good crank out if until it goes to the "RUN" mode. The PCM looks like its setup for TAC and errored out that it couldn't communicate with it (U0107). I looked at the 2004 GTO Attachment 46387 tune to see how it deals with the DBC and it looks like its Electronic Throttle tables are all zeroed out.
Do I need to do a segment swap so the PCM know to used the IAC? Or can I zero out the Electronic throttle tables and will it default to the IAC driver?
