Fuel injectors and ECU tune
Need help on a possible problem. Have a 2010 Camaro 3.6 engine to be run as stand alone in a G body car. ECU is a E-39A from a 2013 Camaro 3.6. What will happen when the 2013 E-39A stock fuel injector tune tries to operate the 2010 Camaro stock injectors. Injectors are the same on 2010 - 2011. Then a different injector is used on the 2012 - 2015. Fuel rails and harness are also different.
Is it possible to add stock fuel and timing curve from a 2010 Camaro 3.6 into a E-39A.
If so does anyone have that file for HP tuners?
Appreciate any input or help in this.
Mike
