There's also something funky in (some of?) the GMPP fan controls, they will run relay fans but not anything variable speed.
Just an FYI, we got the ECM and stabbed it in and the car fired up right away! Thank you edcmat-l1!!!
Now this has created a new issue in that the ECM is reading a constant 158 mph which is
-preventing the fans from turning on and temps are excessive
-preventing the adaptive idle from turning on
For the GMPP OS, HPT did map the fan vs mph settings, including a max temp override (screenshot below), but they did NOT do this for the CTSV OS. If we log a request to map these...what are the chances they would do it?
EDIT: perhaps the 158 mph issue is that [ECM] 822 - Speed Output Type is not mapped either so the trans isn't sending the speed correctly over the CANbus. The GMPP OS has this set to VehSerial, no idea what the CTSV is using. The car is a manual, but the CTSV OS from from an auto (at least as far as I can tell from the VIN number 1G6DV5EPXB0149222).
Attachment 145381
Auto trans ECM OS can only read a VSS if it comes in over CAN, from an auto trans TCM. Only a true manual trans ECM OS can read a hardwired VSS going to the pins used in the OE manual trans car.
2011 Camaro & Corvette but not CTS-V, either auto or manual. Unless the description is badly worded or I'm reading it wrong, that is for the output from the ECM to other modules, not the input from a sensor.
I'm not aware of anyone who has managed yet to get an auto OS to read a direct-wired VSS in a Gen 4. There's supposedly a trick with Gen Vs with the VSS DTCs but doesn't work with these.
https://www.ebay.com/sch/i.html?_nkw...not-programmed
EDIT: or whatever service number is needed for the VIN you want to use, that one may be 09-10, you need to check it yourself
I have several E67 manual trans OS's Erod, GMPP stock tunes.
Attachment 145412
Attachment 145413
Attachment 145414
I got him straight last night. Car is running and speedo is working right.
