1 Attachment(s)
Plot Filtering/setup with negative numbers
Ive been using my innovative WB to log AFR Error % and am tired of getting super lean decel values when running OL No Trims while im straight tuning my MAF and (5) VE tables. It always shows like a 25 to 35% lean AFR because I let off the pedal, Im tired of this affecting the different cell's average making it hard to tuning specific areas. I decided to start messing with plot filtering a little more. my question is; will plot filter work? I basically dont want to see any positive(lean) AFR Error% values if the are more than lets say 6%. This is how I planned on setting up the plot string:
[PID.2151] < 11 AND [USER.9008] < 6
PID.2151 references cam angle to log anything less that 11* cam advance in the "low VE table"(since I have 5 VE tables that all are affected by different cam angle/ranges)
USER.9008 references my WB02 AFR Error % that I have piggied in thru my a/c pressure sensor
The plot filter set above should only log anything less that 11* cam advance and AFR Error % that is less than 6%
