It's his PE table actually.... missed that through the first time... lemme update my post for you.
PE is commanding like 1.3(yes):1 AFR.
http://www.hptuners.com/forum/attach...1&d=1290408816
Am I reading this right? Are you going to try to run 10 psi of boost to a 408 ci motor with stock injectors? Even 60# injectors aren't big enough for this kind of power. I have the same setup and, with 60# injectors and meth injection, I max out my injectors at around 5500 rpm. What kind of fuel system are you running?
Those injectors are WAY too small for that motor under boost. I'd look at something likes these.
