0411 5.7 vortec help
Hello all what I have is an 01 s10 with a 5.7 vortec swap with a 4l60. I can not get the gauge cluster to display the transmission position (PRNDL) how can i read in hpt what position the pcm is reading? The truck runs and drives fine. Also is there a way to read cam offset so I can set the distributor correctly?
Cam offset is a pid in the scanner that you add to the table. Also is this a 4l60e or just a 4l60?
it is a 4l60e and I was looking for the pid but could not find it, do you know which drop down menu it is under?
