3 Attachment(s)
Cherry red header caused by faulty TPS
Long story short my procharged Camaro has sat all winter and when I fired it up I noticed the headers were glowing at idle. I did some logs and pulled the tune and I just want someones opinon if it's in the tune or if I should be looking at another issue. My tuner offered to look at it but due to moving and work I don't have the time to bring the car to them.
In the logs I did use the VCM to command and hold 22 degrees of timing to see if the changes had any effect on the situation to me they appear to but the car never ran bad or had any issues at all.
Setup is
Forged 402 10:! compression, L92 heads, 226/246 Cam, F1A procharger 12lbs, 1-7/8th headers, Stock Exhaust, t56
Just looking for someone's experience if the tune needs work still or if I should suspect a mechanical issue with the car.
UPDATED SEE POST #20
