Attachment 56551
does this help?
Attachment 56551
does this help?
Kind of. I assume you changed the formula to match the one for your wideband?
Picture of the channel list after you've finished the transform?
k, so what shows in that section when you start recording?
Attachment 56556
is this what you mean?
No. Same screen as you showed two posts ago... screenshot that one while logging
maybe this one?
Attachment 56558
THere ya go.
Does the 7.94 in the row that says MPVI 1 -> LC1 stay exactly that or change when you're driving?
Posting a quick log might be easier
it does change, I'm not sure how to post a log.
ok, if it's changing then it sounds like it's getting a signal and the formula is just wrong
What values are you using in this window??
http://www.hptuners.com/forum/attach...1&d=1455675159
initially I used the linear equation that I used with 2.24 volts/0.3324 + 6.35. when it didn't work, I left it blank when I selected the LC-1 predefined values.
LC-1 and LC-2 are already predefined transforms.
Yes
