6.4 Powerstroke - limp mode?
I?m throwing in the towel. Hoping someone can enlighten me. My truck flooded a few years ago and finally some things started to corrode and started my nightmare. Long story short I?ve listed below the parts and modules changed. A lot of it was overdue anyways
- PCM
- TCM
- 15% over injectors
- Electronic non water cooled vgt actuator
- ABS module
- Billet compressor wheels in both stock chargers
In addition to changing parts I also found multiple harness connections that had corroded. Finally after getting everything cleaned up and connected I got the truck running but seems like it?s in limp mode as it?s way down in power (stock power level cal). My assumption is I either did it wrong or HPT doesn?t go deep enough to disable codes so as not to trigger limp mode from missing components? (Egr, dpf, factory lift pump)
Any help would be greatly appreciated. Below is the codes I?m picking up using Forscan
PCM P0232-FF
PCM P0405-FE
PCM P0488-FE
PCM P1335-FF
PCM P1000-FF
