is HP tuners right for me? minor trans issue at idle
The vehicle is a 2007 Buick Rendezvous with 3.5L and 4T65E. (Is it supported? I see the 3.6 and 3.4 listed for Rendezvous, was 3.5 overlooked, or not supported?)
The crossover has never trailered and generally been driven in an average manner (Ohio temps, no hard acceleration, mix of city/highway miles, etc).
I did the first transmission pan drop and filter change at 50,000 miles. I used a real ACDelco filter and Dexron VI as called for.
With a pan drop, I am swapping 8 quarts at a time, from a total of 12 in the system.
There was a light amount of fine paste in the pan and on the magnet.
Around 65,000 miles, I first detected a slip. It happens when you pull away from a red light or stop sign. It is like you are in neutral, no movement at all. It lasts only a split second and then there is a bang and it catches and goes. The weird thing is, there is no rhyme or reason to when it would slip. It does seem more likely to happen when hot, but has done it cold. It could slip 5 times in one day, and then not slip once for months.
At 75k I did the second pan drop and filter replacement. Pan and filter (I cut it up) and magnet all very clean. Fluid had no burnt smell or appearance.
I'm at 93,000 miles now. So it's been doing this for about 30,000 miles now.
A couple months ago I took it to a local independent trans shop that has a good reputation with car guys I know. He connected a scan tool (sorry, not sure which one) and we went for a test drive. It wouldn't slip for him, of course. Subjectively he felt the trans was operating great and the scan tool didn't reveal anything. He looked at the fluid and that seemed good to him as well.
I do want to keep this vehicle for the long haul. Other than this problem, it's probably been my most dependable car purchase ever.
One theory I've been given, is that at idle, the line pressure is very low, and there is a seal somewhere that is slightly leaking fluid past it. Until I step on the gas and pressure builds, car doesn't move.
So I was considering a very slight increase in pressure. Preferably only at idle -- if that can be done by HP Tuners? I would try adding say 5%, test a few weeks, then add more if still needed. From what I have read there is a huge disparity in pressure at idle when in "D" versus "1". So I would not think I'd be doing any damage by increasing it slightly.
Thoughts?
Thank you!
Brian
