What is everyone seeing for start up idle air for a heads and cam LS2
I am working on a friends 06 GTO with a 235/240 cam and TFS 225 heads. I have added quite a bit of air across the entire Starting airflow table but it just doesnt want to start without the pedal. I have tried playing with the cranking VE. Should I max this out to 100?? I have also played with the timing and that didnt help any either. I went as far as to try stock idle timing with no imporvement. I am going to recheck the mechanical side of the house this evening but I was curious how much idle air and RAF should I be needing with a heads and cam setup. TIA
-Joe
