looking for some tune files for dodge magnum 5.9 360ci gas engine
Have you come across any? Anyway you could share you stock file my son has a 96 Ram 360 and was wanting to check out what all can be tuned. Thanks
i have a 2001 Durango 5.9 file Attachment 114014
I'm tuning zj 5.9 for E85
98 ZJ 5.9 and Dodge Ram 5.9 have very different calibration file, fuel & timing
im trying to find a way possible to adjust tire size / speedo with jtec+. doesn't seem to be a way in HPT
Here's a 5.9 magnum base tune
Attachment 137875
I'm also looking for a way to calibrate the speedo. I tried the "controls and special functions" in VCM scanner but it's just blank. Seems the answer is it's not supported on our vehicles. What are our options for changing speedo for new tire size?
Jtec/+ tire size calibration is set in the ABS module. You need a higher end scanner to set. HP tuner only talks to the PCM on Jtec cars. I have a snapon solus edge that does it.
i Replaced my ECu and i have no idea where to get a stock tune for my 02/03 ram with 5.9 magnum
there is no stock tune in repository ?? help plz
