But there is a Scalar that multiplies the G/Cyl output.. that should work w/o needing to scale everything just because you are hitting the top of the table.
where?
:shrug:
wow thanks a lot great idea to use the spark AFR to reduce timing
Just noticed on my logs that the PE/COT table interpolates between values, So now moved my BE/PE values around to take advantage 1.2, 1.225, 1.25, 1.275, 1.3 .... 0 in the 1.2 row, -2 in the 1.25 and -6 in the 1.3
1.20 = 0 timing retard = 0-2psi
1.225 = 1 degree retard = 2-4psi
1.25 = 2 degree retard = 4-10psi
1.275 = 4 degree retard = 10-16psi
1.3 = 6 degree retard = 16-up
1.
-Carl
