what can i change to lessen the hard 1-2 shift on this transmission. this is the only issue i have with transmission. i just got mpvi3 yesterday so this is all new to me. thanks for any info. attached is the current tune, i believe stock
First things first. Before you go messing with a stock tune, does it have a transmission, TAC, or any other codes in the PCM? If so diag those first before messing with the tune. Those do not typically have a harsh shift when everything is bone stock.
0 codes and i forgot to mention po said they put in a corvette servo.
That servo will firm up the shifts.
Shifts are pretty subjective. Do you have a stock vehicle to compare to? You could soften it up with some adjustments.
I don't like to undo shift firmness from shift kit type parts like that.
I'd go back to the OEM servo to get the shift you want.
Thank you. I’ll try this weekend
The 70E servo might be a better choice. (combined with adding some TM at the 1-2)
https://www.sonnax.com/tech_resource...for-the-4l60-e
