I'm working on an 08 Z06 with a Vortech. I scaled the tune using the "double stoich, halve IFR" method. Now my commanded AFR is double what it should be. What do I need to do to get the commanded to read correctly?
It won't read correct unless you scale the long way.
Use lambda and your life will be easier.
Lambda it is then. Thanks a lot Dave.
