Currently tuning a 2008 Silverado 5.3 with the 4l60e and 3.73's, I have removed TM and it is still a dog off the line. Any ideas?Attachment 44027Attachment 44028
brake torque limit? pe seems rich at 1.30 for na? only going into pe at 75% throttle?
It's because your timing takes a nosedive right when the car launches.
timing is that of a FI car. even lower.
raise stall torque management
work on your timing and AFR for more low end power.
i agree with ROG2R. get rid of torque management, tune the fuel delivery, and make sure there's no spark knock. i have the same truck and it gets up outta the hole now.
One thing that helped mine was removing the negative timing in low RPM-high flow rates. I have not opened an 08 to see if they still have negatives or not. Just keep an eye out for knock.
