Found the backfire/misfire problem!
The engine misfires and backfires completely go away when I disable the Kenne Bell bypass valve (keeping it closed). Why is that?
My theory is this: The Kenne Bell bypass valve design is starving cylinder number 5 of air at low loads, and the engine is still giving that cylinder the fuel for the amount of air it thinks that cylinder is getting. So, it misfires nearly every cycle and backfires randomly as well. How can that be you ask?
When the bp valve is open and the engine is at low loads, lots of air is going through the blower and little is needed in the engine, so almost all of it ends up going back through the bp valve to re-circulate through the blower and that is exactly what is supposed to happen, right? Of course, but...
Here is the problem: The KB bp valve is located in such a way that it draws air straight out of the intake runner for cylinder number 5. It draws air from that intake runner and that intake runner only because that intake runner is where they put the routing to the bp valve. So what, why is that bad?
Here is why: As stated above, at low loads, very little air is going into the engine, and a lot is re-circulating around the blower through the bp valve. That means that air at a high velocity (relative to that of the air entering each cylinder) is entering the intake runner of cylinder number 5 and running straight past the intake port and into the bp valve. Anyone know what happens to pressure as velocities increase? That’s right... the pressure goes down - vacuum.
What happens then you put more of a vacuum on one cylinder than the others? It gets much less air than the others and the ecu doesn’t know about it, so it puts in the same fuel as all the other cylinders. That cylinder (#5) then misfires, the driver’s side o2 sensor sees excess o2 and adds even more fuel to bank 2 making a bad situation worse because now all 4 bank 2 cylinders are running rich.
Does this make sense or am I crazy? Is there something else I’m missing?
Info I gathered before discovering the problem goes away with the bp valve closed:
Only backfires through exhaust. I can hear it poping well from under the car, but not really from above the engine.
It only does it at low load such as when the engine is slowing down or if I hold it anywhere above 2000 rpm without load.
It won’t do it at idle, during acceleration, or while cruising.
It happens regardless of ECT and ACT.
It is random/sporadic - not rhythmic or synced to engine speed.
I've replaced spark plugs, wires, IAC valve, and the throttle position sensor.
Vacuum is at about 15 inches of mercury at idle.
I've checked for vacuum leaks by spraying engine starter fluid around the manifold and vacuum lines and didn’t hear any rpm fluctuations.
It also does it when I run my old injectors with my old tune, which never had problems before the blower install.
The AFR fluctuates between about 13:1 - 17:1 while it's happening and only when it's happening.
Timing advance is about 40 degrees when it's happening at 2000 rpm.
