Does This Freezeframe Data Help to Troubleshoot P0430 CEL?
Sorry if this is not the right place but need help to try and figure out the cause of this P0430 engine code.
- Car is a 2021 Camaro ZL1 with an aftermarket CAI and CatBack Exhaust.
- Both primary and secondary CATS were left in place.
- Bought the car with about 1200 miles and the check engine light first came on at about 14k miles
- So far, I have replaced the the downstream 02 sensor on bank 2
- Car doesn't feel sluggish or runs weird at all and no other codes
I can't imagine the CATS are bad this early? Hope this freeze frame data using VCM scanner tells something:
Freeze Frame: 0
DTC: P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
Fuel System Status: 04 00
Calculated Engine Load: 10.5882352941176 %
Engine Coolant Temp: 92 ?C
Short Term Fuel Trim Bank 1: 0 %
Long Term Fuel Trim Bank 1: -4.6875 %
Short Term Fuel Trim Bank 2: 0 %
Long Term Fuel Trim Bank 2: -3.125 %
Fuel Pressure: 444.000463128003 kPa
Engine RPM: 1625 rpm
Vehicle Speed: 115 km/h
Timing Advance: -3 ?
Intake Air Temp: 28 ?C
Mass Airflow: 12 g/s
Throttle Position: 21.5686274509804 %
O2 Voltage B1S1: 37.5 mV
O2 Voltage B1S2: 904.98046875 mV
O2 Voltage B2S1: 12.5 mV
O2 Voltage B2S2: 49.98046875 mV
Run Time Since Engine Start: 1718 s
Fuel Rail Pressure: 4 MPa
Commanded EVAP Purge: 0 %
Fuel Level Input: 72.156862745098 %
Warmups Since MIL Clear: 4
Distance Since MIL Clear: 182 km
EVAP System Vapor Pressure: 16352 kPa
Barometric Pressure: 101 kPa
Catalyst Temp B1S1: 768 ?C
Catalyst Temp B2S1: 718 ?C
Control Module Voltage: 13 V
Absolute Load: 12.156862745098 %
Commanded EQ Ratio: 1
Relative Throttle Position: 11.3725490196078 %
Ambient Air Temp: 27 ?C
Absolute Throttle Position B: 21.5686274509804 %
Accelerator Position D: 20 %
Accelerator Position E: 10.1960784313726 %
Commanded Throttle Actuator: 15.2941176470588 %
Fuel Type: 01
Actual Engine Torque: 7D
Engine Reference Torque: 01 DE
67: 01 84 00
68: 07 44 49 58 28 28 28
6D: 13 01 88 01 C0 00 00 00 01 C2 00
87: 01 02 EA 00 00
8E: 8A
9D: 00 2E 00 2E
9E: 00 E0
A6: 00 03 E0 06
Thanks in advance.
