boost with returnless fuel system
Anyone running boost with a returnless fuel system. I don't understand how you can tune any of these GM vehicles if it is fixed fuel pressure and the IFR table doesn't go into the boosted range?
Does everyone that runs boost install a return line and a fuel pressure regulator referenced to manifold like the old days?
I'm knee deep in fitting a supercharger to an 06 gm I6 4.2. I've been trying to learn all I can so I can tune this thing when I complete the hardware. I hadn't originally planned on changing the fuel system but from what I've come to understand, I don't see how the PCM can get an accurate fuel calculation with a fixed rail pressure and the way the IFR table is laid out.
Anyone help out?
adding return line, how to bypass in tank regulator
I've got the tank out and the aeromotive pump going in and I've added a return line and regulator. I need to bypass the intank regulator but it is part of the jet pump assembly. If I bypass it, I will lose the jet pump scavenging that fills the fuel pump assembly basket! How the heck do you do this?
