Should the upshift numbers be higher or lower than the downshift numbers? Just wanting to build a spreadsheet with a graph to help me out, but I don't recall the order.
Thank you,
Rich
Thank you,
Rich
This should help you. A few shift schedule for a dodge ram
Absolutely. Works great!
what year ram are you tuning?
When tranny tune will be available for charger/challenger/300c/magnum?
For now, all cars I have don't allows to tune tranny.
Does this only work on '04 trucks? Not seeing any support on my '05 yet
There a big need need for trans tuning for the LC LX 08 and up platform. Just to change rear end gear, Tire size,dia. Then its to shift point adjustment and rev limiter, needs to go to 6600 at the lowest point, line presure, clear adaptives, just for a start.
Many trans were smoked in the early days of tuning,,, with the brand XXXX cmr thats out there. Brand xxxx has that much for trans tuning. Just sayin.
Then we get to the vvt tables, woha. Better be on target.
I know and understand the learning curve and applause HPTuning and hope it moves forward. Im all for it.
FlatTop
