Originally Posted by
Keith@HPTuners
If you guys are waiting for someone else to test these to see if it will work for you, you're not doing yoruself any favors. It works for some, and not for others. I can only help those that test it without success and open up support tickets.
Please download the 3.1.310 (or newer) VCM Suite BETA.
In this beta I've added support for the older Innovate Serial Protocol.
The parameters you should be logging during testing are:
Innovate SP - Status
Innovate SP - Stoich AFR
Innovate SP - Lambda
Innovate SP - AFR
If you continue to have issues, you'll need to submit your debug.dat and log file to support so we can look into it further.
If it is working for you, please post the Status while it works. It might say something like Normal (0) or Normal (1).
If it is not working for you, please describe the values you're seeing, as well as the full status Normal (0), Normal (1), etc.. whatever it says.
