unsupported parameters?
Ive been trying to set up the scanner so that I can tune the MAF. I set it up just like Greg B does in his video. I keep getting unsupported parameters. Ive emailed support. They said I need to include the Afr commanded Hi Res. and be connected to car while doing it. I still get the same thing. Since you cant save a custom pid set up Im not sure what to post so you can see. Any Ideas would be helpful. Im missing something just not sure what. A PM or a phone call would be nice, dont know anybody else to bounce ideas off of.
What order do you have them listed in your table?
from top to bottom is Afr commanded hi res,commanded lambda, then lambda err
Where is the wideband in this list?
maybe this will helpAttachment 33991
Fixed it! When I was adding the Air Fuel Ratio Commanded Hi Res, I was adding it wrong. I was doing it the same way as the custom pids and user defining it, didnt know it was under engine/fuel/air fuel ratio. Still learning!
Ok good! I got called into work so I left ya hanging. Sorry brother!
No prob, I was able to tune the MAF today and it turned out pretty good. Thanks for the reply.
