Keep getting P1516 and reduced power
This started happening a few days ago and only seems to happen after going WOT in 4th gear. As soon as I let off the gas a few seconds later it goes into reduced power. I attached the log I did when it happened and there seems to be some strange things going on in the TPS reading at 20 seconds. I have never seen the value go below 20% like this.I will attach my tune as well. The air quality sucks here right now it is hot and humid at night. The KPA is low since I am up around 2000ft but a few days ago I was down by the ocean and it was seeing 100+ KPA but got a lot of knock retard and I hear it ping. I run 91 octane here in California and 32oz of Torco to try to help with Knock but it was getting upwards of 24 degrees of timing and usually I only see 21.5 up near where I live.
Car is 2007 ZO6
Mods:
Ported heads
11.5 compression with 8.55 Dynamic
Ported FAST intake and Nick Williams 102mm TB
Halltech MF 105S CAI - MAF forward style - Also opened up the NACA Duct as Jim Hall suggested
Cam is 236/246 112+4 639/657
Pfadt 1 7/8 Headers and catted xpipe
GZ Vaccu Pump
Stock injectors
Stock MAP sensor
The car was tuned on the dyno to 12.8:1 AFR
