Originally Posted by
mowton
Cylinder Charge Temp (Bias and Filter) s/b offset (like timing table) instead of factoring the contents. Injector Flow rate is fixed across the Manifold Vacumn, s/b linear ramp like stock but scaled by 50% unless you have a Vacumn Referenced Fuel system, Mode vs Airflow s/b offset, not contents scaled, Warmup transient Decay max and min s/b put back to stock, no scaling required, Impact Factor Gain s/b offset, not contents scaled.
Need to run new VE table through BlueCat software to generate new VE coefficients.
Don't forget the tranny Torque...scaling will be offset not contents scaling.
Ed M
