Hi guys,
I have an lt4 swap into a nissan patrol managed to get the car to start i am wiring an rpm gauage that requires the following:
to have a true-tach or a signal with half that rate.
Can anyone support me on this?
Hi guys,
No one
Sorry ... a bit confused.
You are using a standalone E92 ECM, and have wired an output to a Tach ?
You have a useable Tach pulse, but need to reduce the rate (pulses) by half ?
The tachometer requires a true tach signal or a signal with half that rate i dont knw where to get that signal from on e38 ecu there is a pin where u can add a wire and control the singal from ecu
If you are asking where the Tach output is for an E92 ECM, it is J2 (Black) pin 47. However, I don't believe that there are any editable parameters (i.e. Tach type, pulses High / Low) available in the software yet.
Then we need to ask support to add them so we can get proper rpm speed
Do you currently have a pulsed output from J2 pin 47 ?
If so, how much too fast or too slow is it reading ?
Any updated info?
