2 Attachment(s)
Vehicle stalling/surging issue.
I am having an issue with my vehicle wanting to stall when coming to a stop or when letting off the throttle at a low speed. The rpms want to drop real low and then they will pick back up(to much) and then drop down even lower. It wants to repeat this until it eventually drops to low and then it stalls, although it doesn't do this all the time. On my +1 long hour trip home today it did this 5-10 times I believe. When coming to a stop (coast down I guess you would consider it) if I notice the rpms start swinging from 500-1000rpm I have to throw it in neutral and try and hold at 2000rpm and slowly bring the rpms down to try and keeps it from stalling all while trying to not run into the back of somebody. The tune file attached is set up for VE tuning so the MAF is failed but it will still do it with the MAF enabled. If you could point me into the direction of which tables to adjust that would be greatly appreciated. Thanks! Vehicle is a 2011 GMC 5.3, 6l80e 2800 yank, 224/228@114 Cam, CNC heads, stock intake, Ls3 tb, log manifold turbo kit.Attachment 64760
