Looking for performance...let me know what you think about my trans settings
Bump
updated tune
Post a log.
I will later today. I also scratched that tune. I also have an edge tuner...I downloaded the edge extreme tune and modified the trans settings. I will post that tune in about an hour and a log later.
here is the edge extreme tune with modified trans settings
heres a log
I dont like the commanded AFR on the edge tune. I would suggest doing your own tune since you have HPT. What are the specs on the truck? is it a 6.2 what mods?
Its a 5.3 with air raid CAI, flowmaster 40 series cat back
I have been working on my tune for a while, i run 88 unleaded and my high load timing is at 24, and I also worked on my DOD settings for better fuel econ.
can you post a file? what year and mods do you have?
I will after work... But I think the 2011 have a different transmission calibration, as far as pattern y / x, TU/TD
D and M shifter positions appear to be controlled by the Normal table. M being Tap up/Tap down. I believe T/H is Pattern A? Not sure what Pattern B, D1, D2 and D3 controls if anything.
I'll post today
Here is the tune
2009 Silverado CC
Mods are:CAI,TB spacer(I know),Magnaflow CB, MSD wires, TR55 plugs.
Tell me if I am missing anything...
