Throttle Area Opening Rates?
Has anybody tried using the Airflow/Electronic Throttle/Area Rate Limits/Opening Rates/ settings?
It does not work on my E38 2010 LS3 Camaro.
They only list 1000-5000rpm, and they say 100% (As default) will disable them, but I see no difference with 25%.
I would like to do reduce the opening rate of the throttle slightly, just enough to allow the MAP reading to catch up with itself (wacking the throttle between shifts on a Whipple boosted LS3 manual trans causes lean situation due to MAP SAMPLE DELAY).
I've analyzed a couple other Whipple tunes and see the same problem and would like to resolve this nasty issue.
