The Problem is, that if you turn off the ignition, the PCM resets to the "normal" Tables.
You have to reset the relais, too.
I've build a simple circuit with a IC 4020 and some resistors and one transistor
I have an 04 a4 GTO, do you know if I still use pin 71 for performance shift and 31 for manual on my ecu. I have the tune setup and ready to flash, I just need to be sure I'm hooking up to the right pins for the momentary switch.
also does anyone know where I can find a printout of the plug and pin numbers?
thank you!
If it can help, I have maid a how-to (in french, sorry) here : http://www.camaro-firebird.com/phpBB...ic.php?t=20489
Several pictures (some from here :D ) so it can be easyly understood by a non-french I suppose;)
If not, don't hesitate to ask and I can try to translate difficult sentences...
Great, so you can all translate easyly, especially my electronic board http://www.hptuners.com/forum/images/smilies/smile.gif
Hmm this looks interesting and super easy..one wire to ecu and ground switch..Don't get much easier than that!
So can't I simply get stock gm switch and use it. ? Will that still turn off every time car is turned off although not really a big deal. Forget where stock performance switch is since my car is manual. Anyone got a pic. I prefer factory look if possible.
I already was going to use factory switches for my cutout and have nitrous switch panel in the ashtray and still need switches for line lock and two step. Maybe should just get a nice panel for the cubby and can fit all that stuff there.
So anyone know if stock switch would work..???
Um actually lt1 had the stock switch Found pic of it ,was in center console at bottom near back of car.
Has anyone figured out how to do this on a 98 PCM?
Bug me a bit this next week and I will see what I can find. Just haven't been too busy on it, but I will try.
Still looking for an answer on this.
not too bad but it was bitter bitter cold. I have Bill from HP looking into this as well.
Back from the dead....
Has anyone found a way to wire a LED to indicate "performance on"?
Thanks.
what does class 2 do?
V8osaure made a latching circuit:
Too bad it's in French. Can any body translate? Babel Fish doesnt do it clean enough.
