LM1 Help
I inhearted a LM1 from a friend of mine. Using the handheld module it works great, but I am not sure how I get it to work with hp tuners. I have read all of the LC1 info but it is not translating over to my LM1. Since the o2 gets it power and ground from the innovate module do I just need to tap into the signal wire and run it to my MPVI Pro?
Any help would be great.
There should be a small jack with red, white, and bare copper wires. It plugs into the side of the LM1 box. The red and white are analog 1 and analog 2. (or is it analog 2 and analog 1...)
Anyway, you program the output of the analog wire in the LM1 to be the range you want, you setup a pid in hptuners to match, and feed the appropriate red or white wire into the EIO slot. (or onto the egr or ac pressure feed, if you go that route.)
Any idea what the range of the built-in PID for the LM1 is for?
If my math is correct, it's 10:1 to 20:1. I hope that's right.
Thank you, I was missing the analog out cable. I ordered it from innovate and it is now working.
